Pachla
Jul 5 2017, 08:40 PM
The red warning light came on on the dash and the voltage meter went to zero while driving. I checked the battery terminals while the engine was running and got just over 14 volts. When I turned off the engine, the battery read about 12 volts which to seems to indicate it is charging. The belt is on the alternator and the regulator is a solid state type. What should I do next?
Thanks,
Garry
Mark Henry
Jul 5 2017, 08:48 PM
Is that your real email?
If so you should change your user name to just garrysharp or you could get spammed.
PM Sir Andy if you need help with this.
Spoke
Jul 5 2017, 08:59 PM
Check fuse S9. It powers the voltmeter and the GEN light.
Although according to the schematic for a 1975 914, the fuel gauge and tach should also be off.
Pachla
Jul 5 2017, 10:16 PM
The fuse was it. I don't know why it blew though.
porschetub
Jul 5 2017, 10:26 PM
Best to find out why before being happy with a result,truely you may have other issues,good luck.
