I am adding a 6 circuit fuse block to the wiring harness in the engine compartment and I wonder what amp fuse I should use for the 4 red wires that are connected directly to the battery positive terminal. I am also adding one circuit for the audio amp and a spare circuit I added to the passenger compartment (Seat heaters, etc.).
I think two of these go to the regulator plate and two go to the front fuse panel.
I have to think 25A or greater would be fine as I am just trying to eliminate a problem if there should be a dead short midstream, plus it gives ma a nice takeoff point for trouble shooting.
Thoughts?
Thanks in advance!
