I wonder if anyone can tell me the size of the bolt on the lower part of the shock that connects to the trailing arm.
What is the best method of removing the shock/spring?
Do I need a spring compressor to reinstall?
QUOTE (echocanyons @ May 15 2005, 02:02 PM) |
I wonder if anyone can tell me the size of the bolt on the lower part of the shock that connects to the trailing arm. What is the best method of removing the shock/spring? Do I need a spring compressor to reinstall? |
QUOTE (Eric_Shea @ May 15 2005, 01:22 PM) |
Rich, don't be give'n out bad advice or I'll sick the Capt'n on ya! The nut and the unusual shaped head on the pin is 27mm. It's best to remove the 19mm (not 18mm) top bolt and then remove the nut and the pin and slide the assembly down and out. You may need a 7mm and a 19mm open end wrench for the top. The 7mm (best to use locking pliers) to hold the shaft and the 19mm to turn the nut. I use spring compressors on stock springs. 140lbers should need a compressor. |
QUOTE (Eric_Shea @ May 15 2005, 01:26 PM) |
Want a picture of some "Bilsteins" that are exactly the way I described Wienerschnitzel? |
QUOTE |
may need a 7mm and a 19mm open end wrench for the top. |
QUOTE (Eric_Shea @ May 15 2005, 01:30 PM) |
In fact... it's an open end wrench (on my Bils), ya Rump Ranger. And what the hell are we giving advice to a Guru for anyway? He should be telling all of us how to do it |
QUOTE (Eric_Shea @ May 15 2005, 04:22 PM) |
The nut and the unusual shaped head on the pin is 27mm. It's best to remove the 19mm (not 18mm) top bolt |
QUOTE (Eric_Shea @ May 15 2005, 01:02 PM) |
Don't get all fancy pants with me Mr. Herzog. The Cap'n will have ya walking the plank. That's not what poor Kelly asked now is it...? Who gives a rats pitutty about a 18x1.5 spec?? Huh? Huh? You may not have mentioned the "top" nut but he did because you took him out to left field and confused the man with your 18x1.5 bolt/thread spec... poor Kelly. Cap'n, Cap'n, Cap'n... Talk to Rich would ya? |
