I've just now come to the realization how cheaply made the door handles are...pot metal.
I kind of knew it from posts I've seen on the breakage of outside door handles but didn't know that same material is on the inside door handles.
A small piece has broken off of the driver's side door handle (inside), the inside cam that engages the pull to the rod. Now there is only a small movement to the rod but not enough of a movement to open.
Has anyone found a close door handle from another model car to replace? or
Is someone working on a better material replacement?
Dave
