QUOTE(mb911 @ Jul 15 2017, 08:44 AM)
Thanks guy's.. Mark is that sprayed on and then baked? Either way I am good to go now. I have the super expensive 1st under main bearings with number 8 being standard that Mark Epstein found me. Thanks again.
You have to clean, light blast it with a special dedicated media, spotless clean, spray and bake at exactly a certain temp (+/-5F).
Not too bad if you follow the procedure to the letter, ceramic coatings are a lot harder to get right.
Stock 930 pistons with DFL skirts and ceramic coated tops:
