Having a bit of a time with an electrical issue. I’m trying to systemically work this. Below are details and I am slowly going through tracing all wires. At this point I’m looking for insight into something I may have overlooked.
Details:
1975 1.8L / Web Carbs / Mallory Unilite
Issue:
No power when ignition is keyed on and car will not start.
How this event unfolded.
1. Car won’t start. Ran and started great night before but now it’s kaput.
2. Switched batteries suspected due to an Optima RedTOP being too far drained to adequately hold charge.
3. Replaced battery, car started.
4. BUT, When went to restart car ~15 minutes later. Won’t start AND no power for any electrics (Fuel pump, lights). Confirmed battery is charged.
5. Ensured battery was charged, still exhibits same issue. Cannot start and no power at all
Steps taken in attempt to remedy:
1. Replaced ignition switch (old one was cracked, but not horribly)’. New one was from pelican not OEM Porsche. Did not remedy.
a. Have attempted to start via ignition switch via screwdriver in case tumbler was too worn (same result)
2. Verified transmission ground strap was good (yes and it’s only 2 year old)
3. Verified 12V at ignition and at battery
4. Cleaned ground at seatbelt interlock relay
5. Tried to jump starter via a screwdriver across the poles but did not engage.
6. Starter worked when pulled and bench tested. So not enough voltage is getting to starter when in car?
7. Fuse 10, 11, 12 show 12V
Recent work done:
1. -New Clutch (verified transmission grounding strap connection). Drove great afterwards.
2. -Did seatbelt interlock relay bypass
Potential causalities leading up to event three weeks ago:
1. Son washed car and had would not start. Let dry overnight and started next day.
2. Momo horn ring was causing a short and had caused battery drain. Thought I had fixed and car ran without incident for 3 weeks or so until yesterday.
Many thanks in advance!
