jeffdon
Jul 15 2017, 06:53 PM
Getting grey smoke when I pull from low revs, but only until the CHT gets above 200. Then, no smoke. I am running a bit fat on the idles (55's on a lightly cammed 2056). Any suggestions on what I should be looking for?
Tom_T
Jul 15 2017, 08:05 PM
Check the plugs for what type of build-up they have, & cross reference to a color chart from many sources.
https://www.google.com/url?sa=t&rct=j&a...WVegJMtAqO6iKuAhttps://www.ngksparkplugs.com/about-ngk/faq...ad-a-spark-plughttp://www.onallcylinders.com/2012/12/20/r...ur-spark-plugs/Grey or Blue-Grey is usually some oil, so maybe your rings are getting a tad loose then sealing when it heats up, since you said it goes away after the CHT hits 200 - but check the plugs.
Tom
jeffdon
Jul 15 2017, 08:37 PM
QUOTE(Tom_T @ Jul 15 2017, 07:05 PM)
Tom
Thinking along those lines, but I have new rings. Will read the plugs. Runs well otherwise.
