ovation919
Jul 16 2017, 12:06 PM
Hello,
I am starting in earnest on some projects on my 914. I have a pretty good selection of tools but ran into a couple that I needed for regular maintenance.
So far I need.
Replace rear brake caliper mounting bolts.
19mm wrench to remove calipers
4mm and 6mm long throw hex wrench for piston adjustments.
Is there an existing thread where needed tools are documented?
Firstcar
Jul 16 2017, 01:29 PM
Get yourself a Hynes manual and if possible a used set of factory service manual reprints- they will list tools. As for special stuff, metric sockets, wrenches will be indispensable, also ext Ned feeler gauges (.006, .008" ) for valve adjustments; a strobe timing light; dwell meter special 10mm offset wrench for distributer mounting bolt for tuneups; an inexpensive voltmeter for electrical troubleshooting, a breaker bar, and impact driver and PB blaster for stubborn bolts. Wor On my way! And good luck with your 914!
Steve
Jul 16 2017, 01:32 PM
I agree on the Haynes Manual. Also check out Pelican for how to do's. They list all the tools needed per project. Also do a search here on emergency kit or something similar. You will find additional information on what to carry in the car.
sb914
Jul 16 2017, 01:53 PM
914_7T3
Jul 16 2017, 02:00 PM
Jul 16 2017, 02:03 PM
A sense of humor.
Cracker
Jul 16 2017, 02:45 PM
On a serious note...those Esco stands are a must!!!
Tony
Dave_Darling
Jul 16 2017, 09:22 PM
M8 triple-square tool for the CV joint bolts. May also be used on a couple of other fasteners.
A set of Allen wrenches for various fasteners on the car.
A decent floor jack, plus good jack stands.
An offset screwdriver (the little ratcheting one Sears carries is great) for valve adjustments and a few other tight spots.
Deep offset box wrench for the jam nuts on the valve adjusting lugs.
--DD
ovation919
Jul 17 2017, 02:53 PM
QUOTE(Dave_Darling @ Jul 16 2017, 08:22 PM)
--DD
This is all good stuff. Thanks, ordering all of them.
