This was just to be a proof of concept, but it seems to work well enough as is to get through 12 rims. That being said, if anyone has an 5 lug upright and hub just sitting around I could borrow, I'd take gladly take it!
HF Bench Grinder with Kustom PVC pulley HF 8 inch wheel to act as the hub Bicycle inner tube for a belt 5/8" all thread for a spindle 3" wood screws for added hilarity
So jack the front of your car up, remove the wheel, put on the one you want to polish w/ your rig sitting on the floor below it= VIOLA!
-Harry
LowBridge
Jul 19 2017, 01:03 PM
calling it now...second video of the damage caused when the wheel breaks free
Elliot Cannon
Jul 19 2017, 02:36 PM
I would like to polish the propeller hub on my 150. someone suggested I do it with the engine running. I declined their suggestion quite quickly.
yeahmag
Jul 19 2017, 02:38 PM
Elliot,
I would be happy to let you use my top of the line polishing system for the hub. If you want to build one yourself, my licensing fees are very reasonable.
Dave_Darling
Jul 19 2017, 02:40 PM
Someone either here or on FB posted a pic of a wheel polishing rig that involved putting the car into gear with one corner up in the air and the motor running. I think that counts as more ghetto due to the greater potential for damage if the whole car moves than if just the wheel/hub does...
--DD
Elliot Cannon
Jul 19 2017, 02:42 PM
QUOTE(yeahmag @ Jul 19 2017, 01:38 PM)
Elliot,
Thanks. Maybe I'll just polish it with the engine running.
McMark
Jul 19 2017, 02:44 PM
Now add an adjustable, spring-loaded arm to hold the sandpaper for you. Then you can just let it run while you drink coffee.
yeahmag
Jul 19 2017, 02:54 PM
I specialize in automating tasks for Caltech in the realm of IT. You are TOTALLY speaking my language now.
yeahmag
Jul 19 2017, 02:55 PM
QUOTE(Dave_Darling @ Jul 19 2017, 01:40 PM)
--DD
That was me... I wanted to be able to do it at night, under a canopy, and have it be quieter.
Excellent reply,not sure why its needs to go that fast,inner tube ,use a flat ribbed altenator belt that would last better,to the OP glad my computer issues have made some entertainment for you.....
yeahmag
Jul 19 2017, 10:02 PM
We spent some time in Adobe Illustrator, made a template and then redrilled. We also used some of the wheel weights we use for the karts to statically balance the hub. The shakes are gone and I'm on my way.
Not a bad idea but your back is going to hurt when you are 60. Bowling Ball Refinishers make $38,000. Per year! Where a dust mask and wear eye protection.
Bob B
whitetwinturbo
Jul 19 2017, 11:21 PM
Looks more MIT than CalTech.....
Elliot Cannon
Jul 19 2017, 11:29 PM
I used to get the magazine from M.I.T. I remember it had really cool pictures.
yeahmag
Jul 19 2017, 11:41 PM
QUOTE(whitetwinturbo @ Jul 19 2017, 10:21 PM)
Funny you say that. I was at the Artificial Lab at MIT before Caltech.
Blue6
Jul 19 2017, 11:48 PM
Man that's a beautiful dog
yeahmag
Jul 19 2017, 11:53 PM
QUOTE(Blue6 @ Jul 19 2017, 10:48 PM)
She's a good girl. Shepherd Husky mix rescue.
Elliot Cannon
Jul 20 2017, 12:10 AM
Is that the same monster that wanted to chew my leg off when I dropped off a part at your place.
yeahmag
Jul 20 2017, 12:18 AM
I'd guess so. I have two rescues, both the same mix. I did give them your scent to key off of before you came over.
