AndyC
May 16 2005, 05:53 AM
There I was happily laying under the car disconnecting my shift linkage so I had to remove the dust cover where the linkage connects to the gear box. When I removed the cover I became slightly less happy as the dust cover was full of transmission fluid which emptied on my head. I seem to recall this is a dust cover and not supposed to be full of fluid - am I right and if so do I now have to play hunt the leak or will it just be a side effect of sitting around not being used for two years.
Oh yeah its a 901 sideshifter if it makes any difference
Cheers
Andy
JWest
May 16 2005, 06:20 AM
Common leak. It is the shaft seal where the selector enters the trans. There are were some posts on replacing this not too long ago.
AndyC
May 16 2005, 06:40 AM
Found it, Thanks James
Porsche Rescue
May 16 2005, 09:29 AM
Just did the job. Need a seal, O ring and roll pin. I got them from Porsche for $17 total. Probably cheaper elsewhere. Also will need fresh gear oil.
AndyC
May 16 2005, 09:56 AM
Another essential part is two bottles of shampoo to get the oil out of my hair
Have you got part numbers for those bits?
Porsche Rescue
May 16 2005, 10:16 AM
999 701 359 40 O ring
900 112 001 50 Seal
900 309 001 00 Roll pin
Pin above is for the lever at the outer end of the shaft where the shift rod connects. Once the assembly is out and at the bench, you could take off the inner shift fork to disassemble as well. However it takes a different length roll pin.
Rather than driving the pin out with hammer/punch, use a vise as a press. Use a bolt slightly smaller in diameter than the pin and use a deep socket on the back side to receive the pressed out pin. Assemble the same way.
Pay attention to orientation of lever before you remove the pin. You can reinstall 180 degrees out and have to do it all again.
AndyC
May 16 2005, 11:15 AM
Many thanks Jim
