Again my bad
I guess I need to pay attention to my wording
I welded the SHAFT for the triangle piece. (the triangle piece I am talking about connects the throttle rod to the Cross bar linkage and rides on the shaft that broke) The actual shaft is what was broken. The shaft sheared off close to the triangle piece.
The shaft is pressed into the carb manifold and extends out about 2" or so from the manifold and allows the triangle piece to do its job.
I removed the triangle piece and welded the two shafts back together. I then ground the welds down and threw a quick coat of black paint on the shaft. Put everything back together and everything seems to be working good now.
Thanks for the dim's on the the "push-rods"
