Try to find all these parts to match my price.
You can't. You won't. I dare you!
I've been to that place and you don't want to go there.
Just buy mine and you will have the complete setup, no waiting!
914-6 Oil tank (new - Porsche)
GT Oil tank filler neck 80mm - press bypass fitting - repro (Sierra Madre)
GT Oil tank filler cap 80mm - Blau aluminum outer, steel inner, with fin
GT Oil filter console - early 911S magnesium
GT Oil filter console spacer - repro (Barry Pantzer)
100mm allen head bolts - new zinc plated steel
GT Oil thermostat - cast with mounting tab and 26mm ports
26mm-26mm male fittings (2)
26mm-30mm male fittings (1)
20mm-26mm male fittings (2)
GT Oil pressure relief valve - aluminum repro (JKH)
GT Oil lines to front cooler - brass repro (JKH)
GT Oil line solid T-tank-return-pressure relief - repro (JKH)
GT Flex oil line hose - 26mm new (Cohline)
GT Flex oil line hose - 30mm new with green tracer (Elephant)
30mm 90 degree oil line fitting (2) - new (Elephant)
30mm straight oil line fitting (2) - new (Elephant)
GT Argus short line
GT Oil catch tank (67 912 Washer Bottle)
GT Front oil cooler shroud - steel reproduction (mittlemotor)
30mm 90 degree Oil line fitting - used TCH Aluminum
26mm 90 degree Oil line fitting - used TCH Aluminum
26mm 45 degree with 30mm T - steel reproduction (JKH)
Red Purolator filter stamped with Porsche
I will sell the kit for $9k.
Or $8k if you don't need the brand new 914-6 oil tank.
Pics posted on bird board here:
http://forums.pelicanparts.com/porsche-914...oil-system.html
cheers,
dug
