Kerrys914
May 16 2005, 04:49 PM
I ordered some parts today and was told the VR from a 4 cyl will work on a 6 cyl? I wasn't too sure so I didn't order it.
Anyone used a 4 VR on a 6 alt?
Cheers
lapuwali
May 16 2005, 05:58 PM
For the most part, voltage regulators are voltage regulators. They MAY be an issue between generators and alternators, but this isn't an issue if using a 911 v. a 914 part. This assumes they're both still external parts. Some later alternators have the regulator built-in (actually a module that bolts onto the back of the casing, or inside the casing), which can still be used, but are harder to wire in.
Kerrys914
May 16 2005, 06:48 PM
Thanks, I'll be moving to an internal alt once the current one dies. I could put the $150+ to better places right now
Cheers
