Hey experts, I need some information about an engine in a possible purchase. The motor is a 1.7 that has been rebuilt with new pistons and jugs. The pistons were purchased from AA and AA instructed the buyer to get "flat top" pistons that have a lower compression so you can run 87 octane.
I was unaware the stock 1.7 could not run on 87 with it's stock compression?
If it is true that it now has a lower compression how much does this hurt the HP?
The heat exchangers are not installed on the motor so I can't even check if the motor will run. Can I start it without the heat exchangers just to check it? I guess I could pull the ignition wire and turn it over just to check it turns over via the starter.
He has a single carb on it but has all the d-jet FI components. He said he didn't switch the cam so the internals are all stock. How much work is involved to get a FI up and running? I know someone has a link or doc to restoring a d-jet. Will this d-jet work with this lower compression?
Included some pics (shoddy)
