SOLD!
I have one complete Used 73' - 74' 2.0L engine in pieces (boxes): $1500.00 obo plus shipping (delivery available in Northern California) SOLD!
What is included in price:
Engine:
GA Case (STD) (including studs, through bolts, taco plate/sender, oil baffle)
2.0L Crank (STD)/ Rods (impeller hub included with crank)
73' - 74' 2.0L Pair of Heads
Push rods / tubes
Oil Pump (choice of stock or steel 30mm HD pump)
Oil cooler / oil filter stand
both sides 2.0L cooling tins
Aluminum fan shroud w/flaps
(4) 94mm KS German Flat top pistons/cylinders
2.0L D-Jet pieces included:
2.0L Air filter housing
2.0L Plenum with sensors, cold start valve, aux air regulator and throttle body
3 bolt intake runners
Bosch 043 Manifold Pressure Sensor
2.0L Green Bosch Fuel Injectors, rails and fuel pressure regulator
2.0L D-Jet Ecu and Harness
I'm sure I'm forgetting something but all of the little parts will be included (Sorry no flywheel or impeller fan) All parts are used but in rebuildable condition. More Pics of the D-Jet system will be added tomorrow.
