Continuing this saga.
First off 73 2.0 Djet system
it started and ran for a while and then quit. while messing with the relay board I burned up the ignition harness. so it really wasn't going to run then.
Previous thread
http://www.914world.com/bbs2/index.php?sho...=313104&hl=
So as an update I got the car running initially and it would start every time. then on one drive I tried to turn on the heater blower and it just quit. no buzz from the fuel pump. with a bit of fiddling with the relay board I got the pump to buzz and all was good for a bit. After driving about 18 miles, just local, with a number of uneventful restarts I got home. when I went to put the car back into the garage it wouldn't start. so again I unplugged and replugged the relays and the 12 pin connector. that was when I burned the ignition harness. contacted Jeff Bowlsby and ordered a new harness, also ordered new points and condenser since those parts also got burned when the harness cooked.
Fast Forward and I have the new harness, points and condenser installed. but it still won't start. fuel pump runs, I have pressure 35+ lbs, power to the coil full battery. it cranks easily but no start. spark at the coil and plugs. I even got a different relay plate because I suspected the original had a break. all this time I was suspecting it to be a problem related to the relay board or wiring harness
Decided to pull one of the injectors and see how much fuel I was getting and after cranking about 5 seconds I only had a very little fuel in the cup. like less than 1/4 tsp. doesn't seem like enough.
every now and then it will give a POP but makes no attempt to run.
The ground wires for the points are securely attached to the 3 prong connector on the block. the CHT sensor shows around 3400 ohms cold, so its working. there was one fuel hose with a pretty sharp bend so I replaced that. it has 1/2 tank of gas
I had the distributor out to put the new points in but did not check the trigger points, but it did run before, I will check those.
any ideas on what to look for next?
