JFG
Jul 30 2017, 04:18 AM
Can someone tell me the dimensions of the brackets. It would appear I have been sold the wrong ones.
I can cut these and weld them but I don't know how high or low the rubber mount should be.
Ideally I need to know the distance between the middle of the top bolt hole down to the top of the small shelf that the rubber bolts onto.
McMark
Jul 30 2017, 06:19 AM
Buuuuuuut..... I have no idea what brackets you're talking about....
6 conversion mount? Factory 4 mounts? Outers? Inners?
JFG
Jul 30 2017, 06:29 AM
Factory 4 mounts. The ones that bolt to the front of the engine behind the fan shroud
bdstone914
Jul 30 2017, 07:28 AM
QUOTE(JFG @ Jul 30 2017, 05:29 AM)
From the bits on info you offered I suspect you were sold VW Bus mounts. Can you post a picture of what you have? If they are bus mounts you can cut, bent and reweld them. I will see if I can post a picture of a correct 914 mount.
Mark Henry
Jul 30 2017, 07:45 AM
Bus mounts are on an angle, 914 mounts are flat/level
McMark
Jul 30 2017, 07:57 AM
I'll assume you're looking at a side-shifter setup. Tailshifter mount bars use a completely different mount (one piece).
rhodyguy
Jul 30 2017, 08:00 AM
The CORRECT later brackets (for a sideshift trans engine support bar) should be readily available via the classifieds.
bdstone914
Jul 30 2017, 08:19 AM
Good luck finding used ones. I posted a WTB ad with no replies. The other difference is the square mounting hole location. I could not find a bus mount for comparison. I think you can swap the shelf part side to side and bend and reweld them. Or drill a rounds hole. The square hole matches the square on the top of the mount to keep it from turning. If the engine and bar are out of the car I would jig up the brackets to the engine and use the holes in the bar to get the C-C distance correct for the mount holes and get the shelf parts horizontal.
JFG
Jul 30 2017, 10:18 AM
Thanks for the info. It looks like they were bus or other air-cooled as they pointed inwards to each when fitted.
I have cut and rewelded them to fit the engine to the bar temporarily just to get the motor in.
