Trekkor
May 16 2005, 10:05 PM
Wow!!!
Stopping power.
Using R-4 pads all around with Motul fluid.
Throw you foward braking.
Can't wait to take it deep into the turns.
KT
Trekkor
May 16 2005, 10:33 PM
Oh yeah, the price.
$ 99.95 each end from HPH.
KT
J P Stein
May 16 2005, 10:36 PM
Them pads really get the weight transfered forward, eh?
now all you need to do is to learn *NOT* to use them so you can go faster through the AX ...
Andy
J P Stein
May 16 2005, 10:45 PM
QUOTE (SirAndy @ May 16 2005, 08:36 PM) |
Andy |
So speaks a t-4 guy
Trekkor
Nope, I'll go as fast as possible, and then *USE* them *BIG* time.
I'm very excited about using them at Marina, as it tends to be a very tight and quick course.
JP, they are amazing.
KT
J P Stein
May 16 2005, 10:54 PM
I have stock Pagid pads on what is basicly a 911S brake set up. Me & a buddy did 150 minutes (2 tankfulls) one DE day at PIR.....and that was on 225 Hoosiers.
No brake fade....they got to stinkin' some, but no fade.
Sticky tiars & good pads transfer more weight onto the fronts....at the expense of unloading the rears....get it?
May 16 2005, 10:55 PM
QUOTE (trekkor @ May 16 2005, 09:45 PM) |
Nope, I'll go as fast as possible, and then *USE* them *BIG* time. |
can't wait to watch you spin!
Andy
Trekkor
May 16 2005, 11:02 PM
Hmmmm
My spinning days are coming to an end.
It's too much
gas in the turns that gets me, anyway.
KT
Elliot_Cannon
May 16 2005, 11:10 PM
Are these pads strictly for the track or can they be used for the street. I got stock pads and a really bad brake squeel problem.
Cheers, Elliot
Trekkor
May 16 2005, 11:21 PM
This is a guess. I think they will wear out the rotors faster and the pads will not last as long as OEM. My guess.
Stopping power, though. Ahhhhhh!
I'll use 'em on the street.
KT
grantsfo
May 16 2005, 11:29 PM
here's my input. For track they are probably awesome. AX they are hard to modulate. Very easy to lock up at low speeds. They squeak like hell when your rotors are worn.
McMark
May 17 2005, 12:19 AM
I take it your doo-hickey worked?
May 17 2005, 01:50 AM
QUOTE (trekkor @ May 16 2005, 10:02 PM) |
My spinning days are coming to an end. It's too much gas in the turns that gets me, anyway. |
and i *thought* it was your habit to brake in the corners instead of the straights ...
in which case the bigger brakes will make you spin even faster!
Andy
ArtechnikA
May 17 2005, 04:47 AM
QUOTE (grantsfo @ May 17 2005, 01:29 AM) |
here's my input. For track they are probably awesome. AX they are hard to modulate. Very easy to lock up at low speeds. |
could be - i haven't used them.
but *typically* - the way track pads work is that - like race tires - they need a certain (high) temperature to work. they remain very grippy at elevated temps but have basically NO grip when cold.
Porterfield makes -4- compounds in sizes we care about.
there is the Race pad
there is the Endurance Race pad
there is the Vintage Race pad
there is the Street pad.
i'm thinking street is the hot ticket for AX, and i plan to try Vintage Race for DE.
your mileage may vary, but if you're using pads designed for the track on the street, or AX -- watch for that first stop!
tat2dphreak
May 17 2005, 07:49 AM
QUOTE (trekkor @ May 16 2005, 11:33 PM) |
Oh yeah, the price.
KT |
Livermore performace is where I got my R4S(f-$64,r-$59)... they have the R4 also (f-$87,r-$91)
Sean mentioned them a year ago...
Trekkor
May 17 2005, 08:43 AM
Thanks for the heads up on the price. I don't mind supporting the 914 specialist, for a few extra bucks.
Andy,
Joke all you want...
Mark, yes. That air was coming from behind the bleeder valve threads.
The Porterfields get better when hot, yes, but they are much better then what was on there right out of the box.
Didn't feel like I was being unsafe on any level.
If I drag my brakes around the paddock before my first a/x run, they'll be hot when I need them.
KT
anthony
May 17 2005, 08:49 AM
QUOTE |
right out of the box. |
Did you bed them in?
Trekkor
May 17 2005, 09:03 AM
QUOTE |
Yes. Thanks for that detail
BTW, I'm not saying, " Hey everybody, go out, buy and install race pads".
My car is seeing very few local street miles now.
I trailer to the a/x and track, which is why I have these pads.
JmuRiz
May 17 2005, 09:09 AM
I hear the Hawk Performance HPS pads are good for street use, not sure about the track. I think I have a semi-race pad now on my street car...don't bite for S untill heated and squeel like the dickens when doing a slow stop. A switch to Porterfield or Hawk street pads might be the ticket.
phantom914
May 17 2005, 10:02 AM
QUOTE (JmuRiz @ May 17 2005, 07:09 AM) |
I hear the Hawk Performance HPS pads are good for street use, not sure about the track. I think I have a semi-race pad now on my street car...don't bite for S untill heated and squeel like the dickens when doing a slow stop. A switch to Porterfield or Hawk street pads might be the ticket. |
Hawk HPS are good street pads, comparable to the Porterfield R4-S. And yes, I am saying this from direct experience. They don't make a Hawk pad for the 914 rear though.
I got my pads at Livermore Performance, a place I thought I had discovered, but I guess others here have already heard of them. They seemed like good people.
Andrew
tat2dphreak
May 17 2005, 10:17 AM
QUOTE (phantom914 @ May 17 2005, 11:02 AM) |
I got my pads at Livermore Performance, a place I thought I had discovered, but I guess others here have already heard of them. They seemed like good people. |
they were good people to me... I wasn't 100% sure which pads I actually needed since my car is a mid-72, and use the 73+ calipers... they knew, and made sure I got the right ones....
nebreitling
May 17 2005, 10:49 AM
trek -- did you toss the prop valve and use a T?
MarkG
May 17 2005, 01:56 PM
I added the Porterfield R4S pads to the 914 when I did the brake job last week.
Had them on the 308, had to do a panic stop on the mountain road to Cripple Creek to avoid hitting some moron stopped in the middle of the road to look at Deer or something......thought my eyeballs were going to pop out!!
Trekkor
May 17 2005, 04:22 PM
QUOTE |
trek -- did you toss the prop valve and use a T? |
No...
If I get the SS lines, then maybe I'll try the "tee".
The feel with the prop valve in place is very good.
We'll see.
KT
Mueller
May 17 2005, 04:26 PM
QUOTE (phantom914 @ May 17 2005, 09:02 AM) |
Andrew |
I'm pretty sure that you can turn the 914 front pads into rear pads by opening up one of the holes for the pins....pads are identical except for one hole on each pad.....
phantom914
May 17 2005, 04:31 PM
QUOTE (Mueller @ May 17 2005, 02:26 PM) |
QUOTE (phantom914 @ May 17 2005, 09:02 AM) | They don't make a Hawk pad for the 914 rear though.
Andrew |
I'm pretty sure that you can turn the 914 front pads into rear pads by opening up one of the holes for the pins....pads are identical except for one hole on each pad..... |
That's what I remember reading on the site before, but it's not true. The rear pads are physically smaller. I think the rear pads from some makers are 911(?) pads because the rear Porterfields I got had the same size holes rather than one small and one large hole so I had to enlarge one hole on each pad.
Andrew
Brad Roberts
May 17 2005, 04:33 PM
Correct:
The front 914 pads are much bigger than the stock 914 rear pads. We have to drill out all the Porterfield *rear* pads.
B
ArtechnikA
"just" get 914.6 rear calipers and you will be able to find pads ...
Trekkor
May 17 2005, 04:34 PM
QUOTE |
The rear pads are physically smaller... I had to enlarge one hole on each pad. |
Yep, same story here.
KT
