QUOTE(Perry Kiehl @ Jul 30 2017, 10:17 PM)
If you dont know how old the master cylinder is, then you need to inspect it very closely, you want to pull up the pedal board and see if you have brake fluid in that area. If the MC is suspect at all then replace it.
If you are just replacing the reservoir grommets, Bruce is right, it's a tight squeeze, and difficult to get the lines in the MC with the grommets on them. My trick is to use put the seals on the feed lines, and the use a flare wrench and an open end wrench to push the grommet into the boss.
The thing is 6 months old and come to find out its completely broken outside of that leak. Now, because its crunch time, i need a new mc now amazon can get me a 23mm one in 2 days and considering i have boxster calipers it would probably not b so bad. new question is how identical are the mc's (ie fitting placement rod size etc)?
