Full Version: Brakes
Trekkor
So, how far do you push the pedal before you get action?
Mine goes about 1.5 inches and then gets very firm with very good stopping power.
I'm still with prop valve, you should know.
If I replace the rubber lines with SS, I'll try the "tee".
KT
Trekkor
25 views by nobody with brakes?
KT
Aaron Cox
fine. but then i go back to studying.
19mm MC
M calipers
stock rears.
moves about an inch or so, and 1.5-2 inches says lock up.
going to volvo 4 piston calipers up front next month, and replacing my p valve with a teee.
currently my rears do shit!
ArtechnikA
check your pushrod freeplay...
Trekkor
KT
McMark
I'm going about 4 inches. The longer the better right?
My name's Mark and I have air in my brake lines.
sjhowitson
Speaking of brakes...How long will brake fluid last in an unopened can? Factory seal still in place?
Thanks
