db9146
Jul 31 2017, 06:39 AM
Is anyone using MS-3 and driving the stock tach with it?
McMark
Jul 31 2017, 11:49 AM
A lot of the aftermarket tach output is a lower voltage signal. Our early stock tach uses a 12v signal. You can use pretty much any 'Tach Adapter' such as the one from MSD. This takes the low voltage signal and steps it up to 12v. You can also use a late tach, which seems to work out of the box, but you lose the 'silver dot' if that's how your gauges look.
914forme
Jul 31 2017, 03:30 PM
You can also have your stock rebuilt with new internals. Or do it yourself, using a donor tach.
As seen here
VaccaRabite
Aug 1 2017, 07:39 AM
What Mark said.
My MS will drive the stock tach just fine on my car, but my car has a 75 build date. No changes are needed if you have a later tach.
Zach
PanelBilly
Aug 1 2017, 09:15 AM
I have an extra msd tach adapter
