We are currently using this fuel system arrangement on one of the race cars, but may not have fully understood how the system works before implimenting it.. basically, the fuel pressure gauge will read approximately 3.5psi, but bounces between 2 and 7 a's if there's air in the system.
Ha's anyone ever successfully run a return style regulator where it dumps the return back in to the inlet side of the fuel pump? In theory, we were thinking this should work, but I think every time the regulator opens and closes it causes pressure spikes at the inlet side of the pump.. any advice or recommendations is welcomed.
To answer some basic questions...
Fuel pump outputs 14psi, weber want ~3psi, we cannot dump the return back into the bladders because there is only one crossed line (-8), and they both needs vents to allow for the fuel level to move freely . We are currently overpressurizing the needle valves and flooding the float chambers...
We ran the system like this at willow springs months ago, but a 5.0L Chevy with 4 webers at full chat pretty much just burns off whatever fuel makes it into the combustion chamber, regardless of fuel spilling into the chokes.. we were blissfully ignorant to the problem.
