cdmcse
May 17 2005, 12:08 AM
I picked up a used taco plate and oil temp sender set-up off of evilbay with the intention of installing it on my 1.8. The sender that came with the plate is too long to fit into the engine. The plate fits fine, but the sender hits the block before the threads engage with the plate in either direction.
Do I just have the wrong sender or is it not possible to put that on a 1.8? Anyone know the part# for the right sender?
Here are a few pics...
cdmcse
May 17 2005, 12:09 AM
Sender Installed...
cdmcse
I want to put it here...
skline
May 17 2005, 12:29 AM
It looks right to me. I have had them in every car I have owned and they all looked just like that. You are missing the outer shell though. It hold the wire in place. I have seen them without them however.
jim912928
May 17 2005, 07:20 AM
I put one in my 1.8l about 6 mos ago..fit fine. Don't remember how long the probe part is....but I got my sensor new from GPR.
Rockaria
May 17 2005, 08:05 AM
My 1.8 has an add on temp sender that looks exactly like yours and it fit just fine.
I installed it so it points up to the rear of the car. The wire gets connected towards the front. (Bottom front Wire - top rear inside sensor)
cdmcse
May 17 2005, 08:26 AM
I have the cover plate too. I'll try again, maybe I was just having a blonde moment.
Bleyseng
May 17 2005, 08:40 AM
yeah, my probe is too long for the taco too!!
tat2dphreak
May 17 2005, 08:45 AM
QUOTE (Bleyseng @ May 17 2005, 09:40 AM) |
yeah, my probe is too long for the taco too!! |
you wish... the taco just isn't in the mood to be probed
machina
May 17 2005, 08:49 AM
it will fit just fine, no problem, don't worry...
I think
wilchek
May 17 2005, 10:18 AM
angle the plate a little to put it in. It will not go straight up. wire contact toward the firewall and the engine bar. tilt the taco plate with sensor installed (firewall side/engine bar side) down toward the ground an slide in and then flatten against block and bolt up. It should fit.
not the best pic but this is factory install
Bleyseng
May 17 2005, 10:31 AM
Maybe you are putting it in upside down. Doesn't the bulge go on the outside not inside the block?
Flat VW
May 17 2005, 11:17 AM
QUOTE (Mrs. K @ May 17 2005, 09:09 AM) |
QUOTE (tat2dphreak @ May 17 2005, 07:45 AM) | QUOTE (Bleyseng @ May 17 2005, 09:40 AM) | yeah, my probe is too long for the taco too!! |
you wish... the taco just isn't in the mood to be probed |
Yeah or maybe it's that "time of the month"!
Lisa |
ah, Lisa, (may I call you Lisa?)
That is the one thing you women will never fully understand, we do not discuss THAT here.
Hugs, Kisses,
John
cc Laurie
cdmcse
May 17 2005, 11:32 AM
Well, I may have to just get a BFH.
Let's just hope it isn't leaky when I get finished and my car has to park on the wet spot.
Allan
May 17 2005, 11:36 AM
Don't forget the o-ring.
Jake Raby
May 17 2005, 11:38 AM
Must be a Bus case or early 1.7...
Many Bus cases are not cut out for the probe. Also the early 1.7 914 is also not opened for it in many cases...
FYI..
cdmcse
May 17 2005, 12:18 PM
QUOTE (Jake Raby @ May 17 2005, 12:38 PM) |
FYI.. |
Hmmm, I am pretty sure it is a 1.8 case (by the design of the casting), But there is no serial # where it should be. Are there other identifying features that will help me determine if it is a bus case? Is this something I should be concerned about?
Rand
May 17 2005, 12:23 PM
QUOTE |
Maybe you are putting it in upside down. Doesn't the bulge go on the outside not inside the block? |
That's what I wondered. Is the probe sticking OUT the IN hole here...???
Allan
May 17 2005, 12:31 PM
He's got it right. That is how it is supposed to be mounted.
cdmcse
May 17 2005, 01:34 PM
QUOTE (Rand @ May 17 2005, 01:23 PM) |
QUOTE | Maybe you are putting it in upside down. Doesn't the bulge go on the outside not inside the block? |
It has to go that way because of the outer sealing ring.
cdmcse
May 17 2005, 06:26 PM
Well I just checked again and it definatly does not fit, so I must have a bus case
Thanks for the info Jake!
Anybody wanna buy a taco plate and sender
Bleyseng
May 17 2005, 07:05 PM
use the modern VDO 2 1/16 cockpit series gauge and matching sender. The sender is way shorter and will fit the stock 914 Taco plate. I have one sitting on my desk if you want a pic.
cdmcse
May 18 2005, 12:57 AM
QUOTE (Bleyseng @ May 17 2005, 08:05 PM) |
use the modern VDO 2 1/16 cockpit series gauge and matching sender. The sender is way shorter and will fit the stock 914 Taco plate. I have one sitting on my desk if you want a pic. |
Could you shoot me the VDO part#?
Bleyseng
May 18 2005, 08:21 AM
VDO #323-055 which fits the cockpit series oil temp gauge
I did this set up to fit this in my Westy.
cdmcse
May 18 2005, 12:34 PM
Sweet! I think that will work. Thanks!
aircooledboy
May 18 2005, 01:36 PM
