yeah....I DID IT....
went to Kragen got a new v belt for 12 bucks....did excatly as Skline describe...
remove the coil wire, put the belt around both pulleys the best you can and then bump the starter, it will pop right on. Then put your coil wire back on so the car will start.
and it pop right into place...wow that was simple.....
and the G light went off..so it fix...
now I just have to figure out why my turn signal is not working...
ps...I finally get to go pick up my new personalize plate tomorrow....geez its only took 3 months...
