I alway like the dancing banana which Mike Mueller used quite frequently in the past.
The past year I have shifting problems with my rebuild transmission. Originally Doc Evil built the transmission for my 3.2 engine. He did a beautiful job and everything was great until I got the car together running. The problem was the shifting and hanging on the gears at different times. It was nothing that the Doc had done in his build and he did a first class job as always. Changed the entire shifting mechanism from the gear shift down to the side shift assembly on the transmission. Even changed the bushings, tapered pins, universal and bushings, shift rigging, everything possible.
Was not making any headway except a large amount of frustration. Doc was busy with his recent endeavors so I had EBS in Reno look at the transmission where they replaced all five synchros, rev/1st slider(?), and something on 3rd gear.
Still had the shift problem and I associated it with being ok when everything was cold, but when hot the problem would definitely arise.
We recently moved to Rio Rancho, NM where I was referred to an old Porsche racer in Corrales. He inspected the car and found a very simple, logical, irritating, problem cause.
Not yet, Compadres!
First, the Fix was so obvious that I even over looked it and the Doc was not handy to physically get involved. The Doc built a beautiful transmission to the highest level of quality and provides the higher level of advice in helping people. It is an easy item to over look even when inspecting.
Second, EBS are great people who do know a thing or two about Porsche. They did a great job replacing the items they thought was causing it
Third, this is a followup involving a completed solution which I have found is completely lacking in a lot of threads. I am talking about the threads where the fix and conclusion are left open.
Here it is in a nutshell! The cause involves how you may approach a problem. The age old approach should always be KISS (Keep it simple Stupid!). Am I long winded? Yes, I am and am enjoying it for all the time, money, and people involved. Yes, it was my approach and believe me I have read about it but did not take issue with it. Yes, I am a happy camper!
Compadres - here is the problem solution in the complete nutshell
Ah! Hell! I am not going to tell you and just leave the cause and solution as an open item!
Cause and Solution: Outer pin on the transmission shift console. Had the ends of the pins welded so there was not any movement. It appears two items were involved - later pins wear faster than old ones and the holes can be loose fitting. Welding took care of the problem and it is shifting well within the 901 shifting limitations. Makes one a very happy camper!
