I am resurrecting a 72 1.7 914. I have relocated the fuel pump to the front. The fuel pump does not work. Rebuilds are expensive and not readily available.
Can I use the late model fuel pump with only two connectors and run the return directly back to the tank? Lionel-Atlanta (Auto Atlanta on Ebay) advertises the replacement pump as working for all models from 70-76, but provide no instructions.
Is anyone doing this now?
Do you have pictures of the routing of the hoses?
Or should I bite the bullet and get the $400 rebuild of the stock fuel pump?
Thanks,
Bob Johnson
