I've been thinking about what I should do when I rebuild my engine 'properly'. I currently have a stock 1.8 with Weber IDF40 dual carbs.
I would like to keep the carbs, although I can rejet as necessary I guess. The question is, will this carb setup limit the displacement I can run? I guess the choice is essentially building a 1911 or a 2056.
I also want to keep the stock brakes and 4 lug setup.
I'm kind of leaning towards the 1911 cause, well, I'm cheap. But I am worried I will still want more power, and I am sure it will be cheaper to do it now than 10 years down the road.
Thoughts?
