ws91420
May 17 2005, 05:45 PM
Ok no bs answers I need real advice. I want to get my teener running again Memorial Day weekend. Installing new synchro rings, first gear no problem. Right now working on 2nd and 3rd. When I place the ring on the hub and in the dogteeth it is under tension and when I try to put the snap ring on it knocks the sychro ring out of place.. Is there a tip or trick to get the snap ring on and the synchro ring to stay in place?
Brad Roberts
May 17 2005, 05:51 PM
Another person helping. You to work the pliers and another to hold the pieces together.
I have had many of them "fly" apart when trying to do it by myself. It is nearly impossible without help. Some of them go together easily..and some of them dont. It depends on how good of snap ring pliers you have and how much tension is left in the ring.
B
ws91420
May 17 2005, 05:53 PM
Brand new rings lot of tension. Thanks Brad
Brad Roberts
May 17 2005, 05:57 PM
QUOTE |
Ok no bs answers I need real advice. |
I tried
Been there done that.. got the missing eye to prove it (when it slings the thin ring off..LOL)
Good luck. Shoot pics and post them. Many people wont know what we are talking about unless you show them.
B
LvSteveH
May 17 2005, 06:05 PM
Not having extra hands, I had to improvise, so I took a couple thin (1/8" or so) zip ties, connected them to make them long enough to go around the synchro, and put the synchro under tension. That way it just sits there while you put the snap ring in without popping out. When it's together, simply clip the zip, and it's done.
I've done it several times and it works fine.
JoeSharp
May 17 2005, 06:18 PM
I really like this as I am about to start doing my tranny. Thanks Brad and Steve.
Joe
cametal
May 17 2005, 08:12 PM
Zip ties work great, thats how I do it.
Red-Beard
May 17 2005, 08:33 PM
I modified a pair of snap ring pliers, filed the inside, so that I'd get a little more extension. I bet a good tool store would have had ones that would work perfectly.
Pull the synch band open a little so that it has more interference. It will not hurt it a bit. Usually news ones don't need this treatment, only ones I reverse.
I then slip one side under the lip and push it as far as it will go, hold it down with one hand, and use the snap ring pliers with the other and "pop" it's on. The Zip tie idea sounds like it may have merit, and I'll give it a try next time.
Red-Beard
May 17 2005, 08:40 PM
Oh yeah, shameless plug:
Darth Evil, my apprentice, has re-opened the shop in San Diego. Hurry! Less than 2 months to Med School.
