I checked the oil in the 914 and it read about a half quart too much!( I'm always very careful when adding oil or doing a complete change as I recently did). The last time I drove it, the car idled too low at a stop light and died. Had a hard time getting it restarted (but with help from the traffic behind me telling me I'm #1), I finally got it started and crawled home.
The engine rebuilder was messing around with the weber 44's and jetting them down for the now, 2056 engine and he also reset the floats. fuel pressure is 3.5 psi. I thought that one of the floats stuck and either flooded it out ,or starved it of fuel. Then I figured it was because too much pressure from too much oil. I took out the extra to bring it back to normal.
OIL SMELLS OF FUEL !!. I will drain the (brad penn) oil completely out and replace filter.
but, what should I do next? start over with the carbs?
I followed the advice from pelican parts on the jetting, can't say at the moment the size of jets/ac/or emulsion tubes (most likely f11). 517 miles on new rebuild.
