QUOTE(Perry Kiehl @ Aug 10 2017, 07:27 PM)
You can pull back the rubber boot on the master cylinder and disconnect the wires, if the light stops blinking, you have a problem with your brakes or possibly the master cyl warning switch.
It's possible to have a leaky master cylinder and not see a problem from the bottom of the car. Most of the time when they leak they weep out in the cabin floor and you can't see it unless you pull up the driver's side carpet, and maybe the pedal board.
Is the brake fluid low?
Brake fluid is good...but ill try the rubber boot
