QUOTE(mb911 @ Aug 13 2017, 05:35 PM)
QUOTE(HIPPIEKILLER @ Aug 13 2017, 01:24 PM)
Hi!
Are the four available? If yes, do I need something else to convert from 4 to 5?
Thanks!
You will need 911 struts, redrilled rear hubs and rotors so 4 of these would not work.
Also need front calipers to fit the 911 struts, caliper hard and soft lines, inner and outer bearings, strut inserts to fit the new struts hub, dust caps and lug nuts.
Redrilled rear hubs will need studs, lug bolts redrilled rotor and new bearings.
