May 18 2005, 02:21 AM
i'm looking for seam sealer that is close to the factory stuff in appearance.
anyone got any leads???
Andy
Rusty
May 18 2005, 02:58 AM
Check your local auto body supply store... ask for Wurth?
-Rusty
xsboost90
May 18 2005, 05:21 AM
i took some of that heavy duty rock chip guard stuff for rocker panels and sprayed it along the rear seam after POR 15-ing behind my taillights. Seemed to match kinda close.
CptTripps
May 18 2005, 06:18 AM
WURTH BRUSHABLE SEAM SEALER
P# WRTH-8901021
PP has it for about $30 a quart.
http://www.drivewerks.com/catalog/ShopCart...WUGARG_pg17.htm
jonwatts
May 18 2005, 09:25 AM
Why do you want seam sealer?
May 18 2005, 11:43 AM
QUOTE (jonwatts @ May 18 2005, 08:25 AM) |
Why do you want seam sealer? |
because whoever replaced the drivers side rear fender (was done a loooong time ago) forgot to put seam-sealer on the seam under the rain channel for the rear trunk.
now every time i drive in the rain (or pressure wash my fender wells) i have a small lake in the rear trunk ...
Andy
Lou W
May 18 2005, 11:57 AM
I'm looking for something that looks more like the sprayed in kind, not the brushed on. The factory seam filler in the trunk area, looks sprayed on, I think that most of the body protecting stuff that is sprayed on the rockers isn't quite as thick as what I'm looking for, any sugestions?
McMark
May 18 2005, 12:18 PM
You can get a sprayer from any automotive paint supply store. We have one here at the shop for that stuff.
balljoint
May 18 2005, 12:22 PM
The seam sealer in my '71 looked like it had been brushed on. Smooth application, long strokes.
The seam sealer in my '74 has a stipled look that tells me it was either spray applied or was a faux finish done by a factory worker who had been watching too many TLC renovation shows.
Lou W
May 18 2005, 12:31 PM
QUOTE |
McMark Posted on May 18 2005, 11:18 AM -------------------------------------------------------------------------------- You can get a sprayer from any automotive paint supply store. We have one here at the shop for that stuff. |
What brand of sealer do you use? It is deluded down? I've used the 3m type that is applied with a cauking gun before. I also have a spraygun used for undercoating, will that work? Thanks
QUOTE |
balljoint Posted on May 18 2005, 11:22 AM -------------------------------------------------------------------------------- The seam sealer in my '71 looked like it had been brushed on. Smooth application, long strokes.
The seam sealer in my '74 has a stipled look that tells me it was either spray applied or was a faux finish done by a factory worker who had been watching too many TLC renovation shows. |
Mine is a 74 too, looks like it was sprayed on, not brushed on.
Eric_Shea
May 18 2005, 03:18 PM
Early cars were caulked in and then spread around with a stiff bristle brush. No art. No magic. Probably a job for the "new guy" at the factory. This was done in "some" areas, mainly the body plugs. The rest was sprayed in. Again, no art. I know a certain 914-6 that has a 10mm nut "spray" sealed into the back trunk on the major floor seam just under where the jack would go. We laughed and left it there. (Jim's running out to the garage to find it now)
Later cars were sprayed in all locations, even the body plugs.
scotty b
May 18 2005, 05:30 PM
Wurth Rocker Shutz. It is VERY close to the spray on factory sealer, the only problem is it is VERY thick and has to bee thinned to shoot through an undercoating gun!
McMark
May 18 2005, 05:36 PM
Yeah, it must be thinned to shoot.
Lou W
May 18 2005, 06:15 PM
Thanks, Lou
