"maybe", 15x6 or a 16x6 with a 195 width tire for a bone stock rear fendered car.........those running that size rim should be able to tell you if they have an inch between the tire and the fender on the rear (I doubt it)...no problems on the front...it's the rear that gets tricky
some people claim a 23mm offset 7" rim works on the rear of stock fendered car (I don't believe them
the adapters (which are frowned upon) are normally about 1" thick
see the chart below (yes, there is a 15x7 rim that would work with the adapters, but those sell for about $500 each or more if and when you can find them)
