sjhowitson
May 18 2005, 11:24 AM
How do you clean spark plugs. I am changing plug and wanted to clean the old one and use a emergency backup.
Rough_Rider
May 18 2005, 11:36 AM
Carefully & not with a wire brush.
Even though wire brushing is the commonist technique it causes scratches & leaves fragments of metal in & around the plugs electrode. These scrathces & fragments interfere with electrical flow.
If you must clean old plugs, use very fine files to create a sharp angled flat top to the electorde, Do the same to the arm & regap. This gives a nice edge for the spark to jump across. Remove the oil / carbon build up with a solvent which will evaporate off.
IMO the plugs are cheap so replace with new. Or carry some new spares.
tat2dphreak
May 18 2005, 11:42 AM
IMO just get a few extras... but if you really want to use the old one for a spare, spray some carb cleaner on it, and wipe it off with a rag, nothing else...
JWest
May 18 2005, 11:47 AM
QUOTE (tat2dphreak @ May 18 2005, 12:42 PM) |
IMO just get a few extras... |
Is it really worth $2 not to have a new one?
