QUOTE(burton73 @ Aug 17 2017, 11:44 PM)
To get it started try a hair dryer not a high temp heat gun. 150 degrees not 212 degrees or more. Never a scraper inn less it is a softer polyethene If you have a paint job you want to keep.
Is the decal clear with white printed on?
Getting the residual glue off with the Goof Off is good after you get he film off.
Slow going on it. Take you time.
Bob B
Hello Bob
Yes it appears to be clear with white Porsche lettering across it
It is checked and part of it has peeled off
I will apply heat from hair drier and goof off
Thanks
