QUOTE(Garold Shaffer @ Aug 27 2017, 06:32 PM)
You guys do know the pattern is different on the 75-76 model years. It looks like this
I know I have a drivers side card, but can check in the morning to see if I have a good passenger side card.
Thanks and yes I do. The main reason is the PO (35 yrs ago) cut speaker holes in the cards and now I have to remove the cards to repair the door lock plastic cams. My door card are perfectly fine otherwise, without any tears or cuts. I figured while I had the panels off I would clean up the interior back to more original appearance.
