Others may already know about all this but I didn't so figured I'd post to help spread the word: Speedhut will customize their gauges way more than their site implies and more than I thought they would.
Details below:
I've been noodling on what gauges to order for my LS build and really wanted the following in the overall set:
- Tach
- Speedo
AND I want one more gauge than a traditional Quad has:
- Volts
- Fuel level
- Water temp
- Oil pressure
- Oil temp
AND I decided I wanted to keep everything in the stock dash pod set up - vs. gauges in the lower dash or in the console I plan to build.
Adding Oil temp meant I'd had to look at custom stuff. I understand it's possible to take an early Turbo tach and convert the boost gauge to something else but the cheapest core I found was around $700!
Cool, but I'll pass.
I was considering the Classic Instruments "Auto-Cross" series but by the time I add in all the senders, etc, it was one of the most $$ options.
So, back to the Speedhut site. I noticed they make a speedo with a fuel gauge!
Golly, in looking at their Quad gauge, if they'd "just" swap the fuel gauge for oil temp, I'd be all set!
I called them and it turns out for a whopping $25, they do the swap! Yea!
So I ordered the set. I'll post pics once it all comes in but here's what it'll be, except the Quad will have oil temp where the fuel gauge is.
Again, maybe I'm the only one who didn't know they'd do this but if not, now you know!
