Need just a slight mod to make it fit perfect...
Planned for a flat panel display but this should work after I sort out the wiring...
QUOTE (messix @ May 19 2005, 09:14 AM) |
looks awsome. post what you find on the wiring conversion plz. |
QUOTE (Brent @ May 19 2005, 11:07 AM) |
personally , I'm waiting for someone with deep pockets to do this>>>>>> |
QUOTE (Neo914 @ May 19 2005, 11:31 AM) |
I have to be careful about chosing elements that fit the design theme of Neo914. Not too "stylish" since the 914 is more of a functional design. |
QUOTE (McMark @ May 19 2005, 09:30 PM) |
Doesn't that only gain you 1 more guage? I just don't see the payoff. Just curious Felix, I'm not trying to give you a bad time. |
QUOTE (JoeSpark @ May 20 2005, 02:49 AM) |
Hey Neo What year is the Audi ? What you have in your hands is basically a computor. You not only have to worry about sensors...you need to worry about the comunication errors, the second you power it up. Its very hard to reverse Audi Dash coding (depending on the year). It can/has been done, but is it worth the trouble? Maybe check out the "HotRod" sites, back in the day they were pioneers, in the new digital displays. Cheep kits that would be plug and play for a 914. Trust me, you are playing in my back yard... Good luck with it, and if you want to go for it, PM me and Lets Do It ! Later Joe |
QUOTE (Neo914 @ May 20 2005, 07:06 AM) | ||
Joe, It's from a 2000 S4. I priced other displays with lots of features and engine management computers and it would have evolved into quite a project and costs. I live near Sonu who's converted an Audi 1.8 turbo in his 914 using the stock instrument panel and ECU. He was able to make it work w/o too much problems. Once I'm ready to wire it, I'll contact you with any problems. Believe me, I'm counting on help. I have another friend who is German automotive tech with diag equip and I also live near Jason who is converting to Boxster drivetrain. He bought the stock instrument panel and will have similar challenges. Bob, That's nice! I was looking at some smaller fpd's used in some Ultima race cars. I'd like to almost eliminate a dash pod... |
QUOTE (Neo914 @ May 20 2005, 09:56 AM) |
You bet I'll call! I can get the S4 harness but if your A4 works... I'm still getting my V8 together I trial fit the V6 engine and tranny. I get my flared 914 mid June so I can trial fit the drivetrain to design the mounting. It will likely be couple of months before ready to wire. We still need to meet for lunch, how's next week look? |
QUOTE (neo914-6 @ Oct 29 2005, 07:16 PM) |
Mike (Dr Evil) couldn't make the 914 dash work so I went ahead and bought an S4 dash. Surprisingly the length is close but the steering wheel is offset ~2.5" closer to the left side. I plan to cut and modify the complete dash assembly to retain the vents or just use the instrument pod cover and mount it on the 914 dash. |
QUOTE (bondo @ Oct 30 2005, 07:57 PM) |
Why not move the steering wheel? It isn't centered on the seat anyways, and 2.5" may just do it. You'd just have to cut off the mount, reweld it where you want it, and lengthen the rod between the U joints to make it work. Or at least it seems like it'd be that easy. |
