Wyvern
Sep 2 2017, 04:17 PM
I am sourcing a stock front sway bay (none installed)
I have seen the Bushing "bell" and understand how it and the "backing plate" bolt together.
Is it critical to weld as well as bolt?
And why do I see the part pictured below capped off" ... is there a knock out plug ?
burton73
Sep 2 2017, 04:35 PM
People weld in reinforcements to the body. There are a lot of stresses there.
Bob B
amfab
Sep 2 2017, 05:50 PM
QUOTE(burton73 @ Sep 2 2017, 03:35 PM)
Bob B
Hi Bob, are you talking about a kit like Maddog has:
http://www.maddogsmotorsports.org/front-suspension.htmlor something else?
914work
Sep 2 2017, 09:16 PM
Mike Bellis
Sep 3 2017, 09:55 AM
Brian, My car originally had the sway bar without bracing. It started to crack the sheet metal around the mounting points. I opted to fab my own brace material but could have bought the mad dog kit. I highly recommend the bracing.
Wyvern
Sep 5 2017, 03:57 PM
^^^ Thanks to all and thanks Mike.
I am going to reinforce then attach the "nut plate" both from the fenderwell side.
914forme
Sep 5 2017, 07:34 PM
914 LTD
Best design I have seen, and I built a set for both my cars. My -6 is getting the 914 LTD plates, I like it that much.
Click to view attachmentYou do not have to cut the inner fender support with this design.
