Porsche 914, 1972 1.7
Hi Everyone,
I am trying to remove the bolt that holds the seat belt to the rocker panel on the passenger side. It looks like a PO might have changed things up a bit as there is a different looking bolt at this attachment point (vs. the other 3 attachment points). When I try to remove it, it just spins. Almost like there is a nut on the inside of the rocker panel. Question 1 - Is that normal?
Question 2 - There is an "oval-ish" plastic cover next to the seat belt attachment point, in the rocker panel. What does this little plastic cover give you access to if you remove it? The back side of the seat belt attachment area? Or something totally unrelated?
Thanks for any thoughts/advice!
