QUOTE(tazz9924 @ Sep 6 2017, 08:50 PM)
Idk about him but i have no speedo gauge rn (therefor no gps). I am reading my vehicle speed off my cobb access port which is attached to the obd2 port which tells me the ecu thinks the vehicle speed is twice what it is
OK got it, I didn't look at the name to see it was not you.
The assumptions for the system you have are as follows,
Subaru trans that reads from the axle stub or toothed wheel on the final drive.
Subaru ECU wiring harness.
VSS plugged into the Subaru harness.
Subaru ECU with a Cobb reader attached
Some unknown speedo that apparently isn't Subaru.
I'm voting that the reader is showing you KM / H not MPH, are your coolant temps in F? If not, more possibilities are below.
If the VSS reads from the stub axle shaft , or a toothed wheel on the final drive ring gear, final drive ratio won't matter.
For tire size to cause 2x readings, the current ones would need to have 1/2 the circumference of the Subaru. What are the stock Subaru and current tire sizes?
If the trans isn't from the same car as the ECU, perhaps there was a design change along the way doubling VSS tooth count. A low tech way to fix that would be to remove every other tooth.
If this ECU has a speed limiter, you should hit fuel cutoff at half of regulated speed. Has that occurred yet?
