Aaron Cox
May 19 2005, 08:33 PM
just a pic i came across
(obviously a six)
TimT
May 19 2005, 08:39 PM
Aaron thats basically the way you get oil to the turbo.. the factory parts look a wee bit better though
Aaron Cox
May 19 2005, 08:43 PM
i bet they do.
mueller suggested taking oil from the sender zone and oiling his turbo that way (type 4), so this pic made sense.
i suggested the AL oil pump with the feed and return on the oil pump cover plate.
just learning about aircooled turbo motors.
AA
also - whats the best way to get oil back to the case from the turbo?
Mueller
May 19 2005, 08:51 PM
hey aaron....yep, something close to that except I'll have a pressure sending unit instead of the idiot light switch(I'm guessing that is what that sending unit is)
QUOTE |
also - whats the best way to get oil back to the case from the turbo? |
depends on location of the turbo...if high enough, gravity......if too low, then an oil pump will be needed....imchappy used an electric pump and then switched over to a mechanical unit (easier to do with a /6 engine)
iamchappy
May 19 2005, 09:11 PM
Interesting that when my oil pump seized in my engine the idiot light didn't come on, and I showed a little less than 10lbs of pressure. I am tapped into the sender also, I think the mechanical pump was still pulling enough oil through the turbo and the feed line to keep the sender from sensing pressure loss.
Oh by the way I brought my engine in today to get the repairs started on it.
