chunger
May 19 2005, 10:05 PM
hello,
I'm looking for 20/50 Royal Purple. . . anyone know if there's somewhere on the East Bay that stocks the stuff?
-'Chung
Trekkor
May 19 2005, 10:13 PM
Try Griggs Racing out at Sears Point.
KT
bernbomb914
May 20 2005, 12:07 AM
I bouht mine at the NAPA store here in Temecula
Bernie
cnavarro
May 20 2005, 03:06 PM
If you order enough at one time, it might be worth your while to get it from an online retailer such as jegs.com. Worse case scenario- I have the midwest regional distributor in town (he has a big purple warehouse full of the purple stuff) and I can start shipping the stuff for club members.
chunger
May 20 2005, 08:05 PM
Hello,
Cool. I hadn't considered Jegs, but will definitely look into it. I'm not sure how many other club members use the stuff, but if it comes down to it, I can stash a bunch here at my place. . . if in fact the stuff is not easily obtainable here. Seems the Mobile 1 is too thin at 15/50.
-'Chung
Jake Raby
May 20 2005, 08:13 PM
Pep Boys sells it..
I buy it by the pallet- I love the stuff!
anthony
May 20 2005, 08:36 PM
At $8/quart that stuff better be really good! Is this for the car you bought from Rob?
chunger
May 20 2005, 08:40 PM
Haa haa. . .just checked at Jegs, and it came out to 7.50 qt prior to shipping. . . more than Redline. . . must have gold adatives to increase value.
Yeah, Rob's car. Still suffering from low oil pressure so I'm trying different stuff. . . but looks like it's going to get a good dose of "hand-it-to-Brad" sometime.
-'Chung
bernbomb914
May 20 2005, 08:41 PM
I paid $5.99 a qt this after noon at NAPA
Bernie
Allan
May 20 2005, 08:55 PM
QUOTE (bernbomb914 @ May 20 2005, 07:41 PM) |
Bernie |
Why??? Is it really that good? I will run 20-50 Castrol dino for 2000-3000 miles and change it. Is the $6.00 - $7.00 a quart stuff better if you change it often???
Let me know, I have a brand new motor and I want the best for it.........
bernbomb914
May 20 2005, 09:46 PM
back in the olden times when the super vee ran 1600 air cooled enginesWilbur Bunce would build them to rev to 8500 rpm but you had to split the case after 3 hours of racing with valvoline which we got for free. when we went to a syn oil we could run for 9 hours before we split the case. made it worth while.
Bernie
bernbomb914
May 20 2005, 09:50 PM
super vee
Jake Raby
May 20 2005, 09:59 PM
The oil in my 912 E right now has 12K on it- last oil change before that was 18K with a couple of filter swaps..
Royal purple is worth 10 bucks+ a qt- in my testing it perfeormed better than ALL of the 10$ oils out there...
It also stomped the shit out of Mobil 1 in the TIV engine, almost 20 degrees difference in oil temps on the same run, same day, same load same test duration...
I plan on more of this now that the loger is set up- I can change the oils and walk away from the engine...
Looks like its time to send out begging letters to the oil Mfrs again- it gets expensive fast!
The next round of tests I want to log pressure differentials at differnt parts of the engine's oil system with different oils at different temps...
Eric_Shea
May 20 2005, 10:16 PM
You mean Royal "Aubergine" don't you?
chunger
May 21 2005, 03:00 AM
Do you think the temp difference between RP and Mobile1 in the type IV is due primarily to the weight difference alone? Or to the lubricating effects?
-'Chung
