Being maxed out on camber should not influence how much toe you decide to go with, in front or in back. Zero toe in front should be fine. I use toe out personally, but my car is track only. You can try .1" toe in back. I use more than that to counter flexing, but it should be a good start. Don't worry about the camber for now. More would be better, but I don't think that's going to be the source of the wandering.
You mention above that you added bump steer. Do you mean that you added a bump steer kit? If that's what you meant, you still need to measure your bump steer to make sure it's really been minimized. It varies widely from car to car depending on ride height, tire/wheel sizes, and other factors.
In case you're not familiar, here's an article on Longacre's site about how to do it =>
http://www.longacreracing.com/technical-ar....aspx?item=8162. Of course, they want to sell you an expensive tool to help measure it. You can DIY it and get pretty close with string and a tape measure, or make a tool yourself similar to the one soe vendors sell if you are handy.
Re: adding weight, I would not choose that option. Your car is at a nice weight at 2360. That should not be your issue.
Scott
