TonyA
Sep 13 2017, 11:38 AM
Can anybody tell me where i can purchase a short car hauler. I want it to tilt also so that i could also use it to transport a scissors lift for work.
EdwardBlume
Sep 13 2017, 12:11 PM
QUOTE(TonyA @ Sep 13 2017, 10:38 AM)
Trailer manufacturers can be regional. I bought my trailer from Carson out of CA. You can get a drop axel to make it lower, and equipment / cars can be more easily loaded with a dovetail and longer ramps.
Good luck!
bbrock
Sep 13 2017, 05:34 PM
For what it's worth, I have a small (5'x9') tilt utility trailer that I absolutely hate and will never buy a tilt trailer again. The axle is in the middle to facilitate tilting which often makes it difficult to get enough tongue weight on the load. Without the tongue weight, the trailer is downright dangerous as it whips and bucks at any speed over 40 mph. I'd much rather have a drop axle trailer equipped with ramps.
914Sixer
Sep 13 2017, 06:09 PM
Look for a roll back tandem trailer.
Mike Bellis
Sep 13 2017, 10:02 PM
Buy one in Texas. All trailers are way cheaper there. I bought a 24' 5th wheel there, brand new for $13,000. Same exact trailer in CA was $26,000. I drove to go get it spending an additional $1,500 in gas, food and lodging.
JRust
Sep 13 2017, 10:13 PM
I had a 14x7 single axle tilt trailer that was kick ass. I wish I could find it to buy it back. Was the only trailer I have loaded 914's on that didn't scrape at all. A nice tilt trailer is hard to beat. I brought my Scissor lift home with it & it was so simple. Having a winch on the front helps too
toolguy
Sep 14 2017, 08:00 AM
I tried to find a prebuilt with low clearance and had no luck. . Built this one myself. It has 4 inch dropped axles and a 2 inch arched curve built into the rails. jacked up with the tounf wheel and the ramps to the bed are a straight shop. . My car has 3 inch ground clearance and it is an easy load for 1 person. Axles set a little rearward for good tongue weigh with a rear engine car. . Tows like there is nothing behind you. . 13 foot bed and 6 foot tongue so it fits in the garage with the car on it.
I have a slight dip in my driveway so the car is an easy roll on and off.
jeff
Sep 14 2017, 08:28 AM
Nice build, I'd like to see more pics of that..
toolguy
Sep 14 2017, 08:57 AM
Here it is built and being primed before paint. . All framing was made with structural square tube, finished weight was right at 1500 pounds with dual 3500 pound axles. .
diamond plate side steps all around and full fenders. . Only bad part is the cars doors wont open completely once loaded so access is with top off or crawl out window. .
Andyrew
Sep 14 2017, 09:01 AM
I want to design and build something like this...
http://www.futuratrailers.com/
Mark Henry
Sep 14 2017, 09:37 AM
I built this one in the early 90's,
Optimusglen
Sep 14 2017, 10:33 AM
I always thought this was cool, no idea if something like this would be ok to live with though.
andys
Sep 14 2017, 01:40 PM
When I towed my car to Willow Springs, a friend loaned me his Featherlight aluminum tandem trailer. It had fold-down fenders, which is a great feature! No crawling over anything.
Andys
TonyA
Sep 15 2017, 11:32 AM
Thanks for all the input guys. I may wind up buying one which is longer than what I wanted at 18'. It power tilts and jacks needs a little work.
914Sixer
Sep 15 2017, 01:10 PM
Here is my 14" tandem trailer with the 75 914 on it. I paid $1500 for it with new tires and wheels. The ramps were included in the price. I added the front mount hitch for the winch. Lots of room at the back.
Porschef
Sep 15 2017, 04:28 PM
Foley has the best one, my car spent some time on it
But it's custom designed for the 914
914forme
Sep 15 2017, 04:36 PM
QUOTE(Andyrew @ Sep 14 2017, 11:01 AM)
http://www.futuratrailers.com/ Where do I sign up
Mark Henry
Sep 16 2017, 01:07 PM
QUOTE(914forme @ Sep 15 2017, 06:36 PM)
I want to do some design changes to my trailer.
Mine's a single 3500lbs axle which with a SUV is more than enough for 914, bug or split bus.
If you haul more than 3000lbs you want a dual axle trailer and a full size P/U.
Here's some more ideas, the dove tail makes it nice to crawl under to chain up the rear. Nice feature as I know it's a total PITA doing this deed on a regular trailer.
[/img]
type2man
Sep 16 2017, 03:15 PM
Trailers are for boats.....
