Calwaterbear
Sep 13 2017, 11:54 AM
so I've hit the floor pan, inside and outside with the rustolium rust reformer.
so do I paint another coat over that? and iff so? what? just an enamel?
burton73
Sep 13 2017, 02:43 PM
From Rust-Oleum__ Not sure if the stuff works or not?
ABOUT RUST REFORMER
Stop rust in its tracks with Rust-Oleum® Automotive Rust Reformer. Without sanding, the coating bonds with rusty metal transforming it into a flat-black, non-rusting surface.
Instantly convert rust into a protected, paintable surface
Prevent future rust and corrosion
Odorless, water soluble and safe to apply
Compatible with oil-based, lacquers or aerosol top coat paints
FOR BEST RESULTS
Apply several light coats a few minutes apart to prevent running and sagging.
AVAILABLE SIZES
Rand
Sep 13 2017, 02:54 PM
I use Ospho. Great rust converter. But I would NEVER use that as a finish. Definitely paint over it to give you a better chance of keeping it from coming back. Seal it!
Rust needs oxygen. Better to suffocate it than risk feeding it.
