Found this on the TWM throttle body website....
not only is it for the linkage, it also doubles up as a common manifold for MAP readings for fuel injection....
QUOTE (SirAndy @ May 20 2005, 12:21 PM) |
another problem with this setup, the movement of the throttle blades won't be linear! in fact, it'll be a copped off SIN Curve ... i'm not sure what that does to your rpm/hp/torque graph ... Andy |
QUOTE (jhadler @ May 20 2005, 05:10 PM) |
Have you bought the throttles yet? If so, where from? |
