Freezin 914
Sep 17 2017, 11:37 AM
Hi all, can intake manifolds and air cleaner assemblies be repaired if cracked? I have a manifold tab that broke where it mounts. And have an air cleaner assembly that the linkage mount broke, can these parts be welded? (Parts are cast) I was looking to list these carbs for sale and want to know if it is worth trying to have them repaired or just sell the carbs separately. Any info would help. Thank you.
Freezin 914
Sep 17 2017, 11:38 AM
Manifold
nditiz1
Sep 17 2017, 11:40 AM
You could repair both via welding and redrull the hole for the manifold, but you are better off just getting a used manifold and some new linkage
green914
Sep 17 2017, 11:41 AM
I think you should replace with new parts.
Freezin 914
Sep 17 2017, 11:48 AM
Thank you for the quick replies, I think it will be best to just list them without the manifolds and air cleaners, thanks again.
mb911
Sep 17 2017, 02:27 PM
I specialize in repiaring aluminum and magnesium castings. I would think these appear repairable fairly easy..
Freezin 914
Sep 17 2017, 02:46 PM
QUOTE(mb911 @ Sep 17 2017, 03:27 PM)
You have my number, whenever we meet up, we can figure something out. Thank you.
mb911
Sep 17 2017, 02:53 PM
Wow didn't even realize whom I was replying to.. Yes definitely will .. I
rhodyguy
Sep 17 2017, 02:57 PM
Just sell the carbs by themselves or with the velocity stacks if you have any. Broken castings just add to the shipping cost.
DM_2000
Sep 17 2017, 05:42 PM
The manifold is repairable without much effort. The linkage mount is repairable but would probably be less $ to replace.
Always let the buyer decide if they want the broken parts shipped. It is far easier to repair a cracked part then it is to make you own from a sand casting.
IronHillRestorations
Sep 17 2017, 05:59 PM
I'd JB weld the piece back on the air cleaner base, after cutting off the cross bar mount, and then use a CSP center pull.
Take the intake to a welder who can do aluminum.
Freezin 914
Sep 17 2017, 09:22 PM
Thank you for all the replies, I listed the carbs, I will hang on to the manifolds and air cleaner bases for now. Thank you all.
