krazykonrad
Sep 18 2017, 08:41 AM
Click to view attachment Is there any performance advantage here or is it just to back off the compression ratio to avoid pinging?
Thanks,
Konrad
Dave_Darling
Sep 18 2017, 11:34 AM
In theory, sharp corners would provide hot-spots that would promote detonation.
In practice, I'm not sure it matters unless you have tuned your engine to the Nth degree.
--DD
Mark Henry
Sep 18 2017, 12:27 PM
Also called the Semi-Hemi, I used to do this back in the early nineties.
OK if you want to lower your CR, but I've found doing the math and shims under the barrels do a simpler and performance wise better job.
HAM Inc
Sep 18 2017, 07:31 PM
Sharp edges in iron heads are a problem as they can light off under pressure, like a glow plug.
Sharp aluminum edges turn dull when they get that hot, preventing the kind of pointed hot spots that light off.
