This is a plug and play kit to install all the engine compartment oil lines for a 914-6 GT. I patterned these after my Factory Original oil lines and built them with O.E. Cohline hose and fittings (these are the later type fittings that are crimped onto the hose). Also included is a Factory 911S aluminum oil filter council with fittings, spacer (also patterned after my original), a 914-6 GT Thermostat with the mounting flange, an oil pressure bypass valve (Jeff Hines) and finally a large oil filler neck & cap (SMC) and of course all the special oil lines to tie this all together. SOLD!
Thx,
Bernie bbuschen@comcast.net
